- Mar 31, 2016
- 106
I did wonder how you made the slot, I thought you might have had a long milling tool and set it up on your
horizontal mill. I though going in from each side of the barrel a bit risky but if the two cuts didn't meet exact
it wouldn't matter as long as they could be cleaned up later and there was enough clearance for the worm wheel.
If i was to do it again, now knowing that I can make the slot, I would cut the flats for the spindle bore first
because it would be easier to reference on the larger area of the flat to cut the slot that the inside of a slot to cut
the flats.
I checked back on your thread #65 and I can see what you mean. Yep I can do that. And looking at your post
again after I have done a bit more turning I realize just how good the quality of your work is and the finish you get
is beautiful.
I will get in the shop again today I will post my progress.
the flats.
is beautiful.
