- Dec 21, 2018
- 2,170
I've got a BS-1, Import, it is quite nice. I've never used it in the straight up configuration. I'd guess that if it was used that way it would normally be with the chuck mounted. That takes a lot of Z! If you think you are going to do spiral cuts then the universal head is your choice. Complicated - time consuming to set up!
My BS-1 isn't overly heavy even with the 6" chuck mounted. When set up for making Spur gears, dead centers are used on both ends.
The only thing I don't like on my BS-1 is the handle with the spring powered pin to fit in the indexing plates. When turning the handle through several rotations it wants to let go of the index pin. Someday I'll fix that. Or learn how to properly use it!
