I'm still working outside the shop (with insects visiting my ears, etc.).
I had to make holes on a board, to bolt it to an iron bar with threaded holes: of course these holes must be precisely located, at least within 1 mm of tolerance. After all it's wood, not metal…
The threaded holes are because I can't use carriage bolts on the last board or it couldn't be tightened, because there aren't passages to reach the nuts below it.
Nobody here seems to know what a "transfer punch" is, and not even a "transfer screw". I guess if I tell the name Heimann some clerks will think he is the goalkeeper of the Borussia Dortmund soccer club :rofl:
So, as usual, I had to make something by myself.
Here is my shop made version of a transfer screw:
It's just an M8 bolt with the end sharpened with the grinder, but it makes nice starting holes in the wood and the board went precisely on all the threaded holes.
The trick is to use a well charged cordless screwdriver with a 13mm socket from the bottom and to keep a wife on the top of the board as counterweight. Maybe a heavier mother-in-law would be better, since at the first turns I lifted wifey a bit…
I think this method can even be used for metals, with some hardening of the bolt tip.
