- Feb 17, 2013
- 4,409
Had some fun with JB Weld.I mixed up some JB Weld for a project a couple of nights ago, and had some left over. For no good reason at all, I decided to set the blob over a rare earth magnet. It was interesting to watch the blob coalesce over the magnet.
It was nicely cured today, and the iron content of the epoxy was definitely concentrated over the magnet, because the magnet would only stick to the center of the blob's bottom surface. I cut the blob in half and sanded one side to as smooth a surface as I could, and took the following photo:
You can plainly see the classic "lines of force" pattern of the iron particles. For scale, the magnet is a 1/4" cube, and the blob is about 3/16" thick and 1" wide.Things I learned-
(1) JB Weld does contain iron, but not a whole lot of it
(2) If someday I need a surface that's only attractive to a magnet in a certain area, I now know how to do it!
PS - Post-it notes are great for mixing small amounts of epoxy. They're cheap, they stay put on the table while you're mixing, and they're portable, so you can take the mixed epoxy to the job.
