You grumble about finding a way to stiffen up the column on your mini-mill some more and your wife says "Viagra?", chuckles to herself and walks away shaking her head. Happened this morning...
Viagra pills stuffed inside the column? Sounds expensive :biggrin:
When you clean out your pockets at the end of the day and there are 2 10-32 set screws, a cotter pin, 2 3/8-16 hex nuts, and a #29 drill. You then put them in dedicated jar on your dresser beside the loose change jar. Oh by the way, your wife accepts it as normal!
