- Dec 20, 2021
- 883
None of these will stop a direct hit. If Thor wants to smack your computer, there isn't much you can do about it. I've seen lightning vaporize coax cables. I've seen it vaporize 6" every few feet inside coax cables with no apparent damage to the jacket. It goes where it wants to. The best chance you have to stop it is to give it a good path to ground away from equipment/people/pets etc.
The hits we had summers in a row weren't direct hits. But they were darn close. To my best guess damage was capacitive/inductive coupling. That is, it didn't generate differential surge on the AC line it generated a huge common mode surge. This would have appeared on the AC lines AND Ground, ethernet, and antenna wire lines. The long cabling involved in the installation give multiple paths for common mode on the individual cables. Since the paths were different, they were of different potential. When they finally met in the computers and power supplies for equipment, the difference between those common mode voltages was enough to blow things. That's where the damage happened.
None of the surge suppressors or isolation transformers I know of are any good at common mode spikes like THAT. If the common mode spike doesn't have a loop to dissipate power in, it's a lot harder for it to do damage. So that's why the fiber now. Since moving towards fiber, lightning hasn't shown itself to be a problem anymore.
So, my next machine...will be yet another computer for data logging! lol
