What he said...
Price difference not much and if you can find a dealer with units on the floor and have folding moneymany can have arms twisted this time of year.
Remember looking at Curtis units when shopping for current model, almost went with them as it first home built was a Curtis pump with poured babbet and trashed crank.
Used connections at former employer to turn journal to just clean up and pour babbet to fit.
Worked great but too small.
The Curtis did not have near the features the Champion did and it was many hundreds more expensive.
Ours is using a 50 amp range outlet, cannot remember wire size or breaker, with the unloader it never starts under load and being 2 stage does not work that much harder than single.
The motor protector has tripped a few times but we have it set lighter for better motor protection.
We added a 120 vac coil relay inside the starter with a standard cord on the coil.
This plugs into an outlet next to main power wired to lights.
Pressure switch control wire goes through relay and added toggle switch so we can control operation with simple switch and interlock to lights so is off automatically when we turn out lights.
Also added 120 vac air solenoid so supply air also off so the tank stays full if we forget to close the ball valve (hose reels have slow leaks)
Sent from my SAMSUNG-SM-G930A using Tapatalk
