- Feb 27, 2014
- 2,130
about $760 USD with free shipping. No coatings. or upgrades.How much did that set you back? And did you opt for any upgrades in coatings?
Excellent you just put a parts list together for the perfect home shop air system. It will allow the shop to grow and out perform any of the throw away home shop compressors and the price is not that far 2k I saw on one of the better compressors I saw at my local RKO or Lowe's, Home Depot.Running compressor pump (5-10Hp) with low hours or new, probably run you around $1500, tank around $700, single phase motor $500, electrical, plumbing, guard, you are well past what a new one would cost. The pressure lubed compressor series in the Quincy, Curtis and other industrial lines are made for continuous use for years, but way overkill unless you can pick one up in good condition and do not have to start rebuilding it.
Example of a Quincy 350 Compressor is a good compressor, very low hours, might get lucky with a low sale price. These days I just want something I can hookup and runs, and I do not need to think about it for many years.
Quincy 350 Compressor | eBay
Find many great new & used options and get the best deals for Quincy 350 Compressor at the best online prices at eBay! Free shipping for many products!www.ebay.comIndustrial Air Vertical Receiver Tank w/Platform- 80 Gallon 200 PSI #021-0422 | eBay
Find many great new & used options and get the best deals for Industrial Air Vertical Receiver Tank w/Platform- 80 Gallon 200 PSI #021-0422 at the best online prices at eBay! Free shipping for many products!www.ebay.com
How are you going to have this compressor explosion? The key to compressor safety is the pressure relief valve.
Damn that's scary! These are small economy compressors and the tank quality does not compare with a larger certified tank.The pressure relief valve has no bearing on the tank structure rupturing due to corrosion. The tank structure can rupture at well under the rating of the pressure relief valve if it has corroded enough. So again - your pressure relief valve is irrelevant in that case.
All a pressure relief valve is going to protect against, given it is functional, is over-pressure. If the pressure switch fails and the compressor runs past its' cut-off point then your pressure relief valve is going to be the saving device.
If the compressor cuts off at 175psi and the pressure relief valve is 190-200psi, yet the tank ruptures at 120psi, what is the safety device?
So again - I wouldn't trust a used system (specifically the tank = pressure vessel) without documentation, proper inspections, and having the ability to physically inspect myself.
Here is some insight for compressor explosions:
Metropolitan Engineering Consulting and Forensics - CAUSE OF EXPLOSION OF AIR COMPRESSOR TANKS
CAUSE OF EXPLOSION OF AIR COMPRESSOR TANKSsites.google.com
