- Jun 12, 2014
- 4,819
I do not think you will find a compressor that has all US parts, just about everything these days is sourced from different countries, made in US does not assure one of quality. Compressors in the 2-3K price range are built on pretty much the same pump designs that have been used for decades. So the parts may be outsourced, but the should meet the same spec's, the pumps are typically rated for a minimum of 20,000+ hours, so it comes down to the pump speed/CFM, noise, and additional features. Probably more a matter of preference whether you go with a Curtis, Quincy, Saylor Beall or Champion. Price wise the Champion's tend to be a bit less expensive for a similarly equipped model. In the Champion line-up their "RV" line is a less expensive line vs. "R" series, the latter is more industrial and may last a bit longer in a continuous use mode. I have the "R" series, it was quite a bit less when I purchased it, it works fine. I also had the industrial Curtis CT-5 5Hp and it was also built to last. I put so few hours on my compressors, that it is pretty much a non-issue of their longevity. If you can swing the extra cost, as I mentioned the after cooler and automatic drain are well worth additions at a nominal additional cost in the packages. Typically the entry level 5 Hp models by these manufactures will use higher speed (Asian) pumps and motors, so more noise, and they seem to have more reliability complaints. I have a Marathon motor on my compressor, seems they have moved away from Baldor, they also use WEG industrial motors. Almost all these are now made in Mexico or Brazil, the cheaper ones are typically Chinese.
On the issue of supply current and breakers, you want to use the minimum specified gauge wire outlined by the manufacturer, typically #8 for 5 Hp and #6 for 7.5 Hp 230VAC single phase. Minimum breaker size is 1.25 x FLA. So at least 30A for 5 Hp and 40A or 50A for 7.5 Hp depending on the motor FLA. In addition a breaker at a specific trip amperage is not to designed to provide that amperage continuously, it is designed to deliver 80% of it's rating on a continuous bases. So a 40A breaker can supply 32A continuously. On a compressor that cycles on and off, you may not hit the thermal overload limits of a breaker, but depends on/off duration over time.
This is a breakdown of the Champion models:
Full package includes After Cooler, Automatic Drain, Low Oil Shutoff, and additional add on's based on the seller. Compressors most be hard mounted with isolation feet. Warranty varies by series and package. Stripped down packages are approximately $600-700 less, but as noted may not have mag starters and motors on the RV series may be 3600 RPM. I purchased my Champion Compressor from Pacific Air, there may be some wiggle room in pricing. I got the runaround from some of the other dealers, had the check valve to the tank fail due to rust, and they replaced it under warranty. I am surprised that they no longer list the "R" series on their website, but could probably order one.
VRV "RV" Series
Champion 5 HP 2 Stage 1 Phase Air Compressor VRV5-8 Full Package, 17.3 CFM, 734 RPM Pump (21A, 1750 RPM motor) ~$2700 shipped
Champion 7.5 HP TWO STAGE CAST IRON V-4 CYLINDER AIR COMPRESSOR, 25.8 CFM, 575 RPM Pump (FLA 31A,1750 RPM motor) ~$3400 shipped
VR/HR "R" series, Advantage series are the fully packaged.
VR5-8 Champion 5 HP 80 Gallon Vertical Advantage Series Air Compressor Fully Packaged 17.3 CFM, 710 RPM Pump (21-23A, 1750 RPM motor) ~$3200 Shipped
VR7F-8 Champion 7.5 HP 80 Gallon Vertical Advantage Series Air Compressor Fully Packaged 28.7 CFM, 990 RPM Pump (FLA 40A,1750 RPM motor) ~$3400 shipped
VRV "RV" Series
Champion 5 HP 2 Stage 1 Phase Air Compressor VRV5-8 Full Package USA Made!
Reciprocating Air Compressor 5 HP, Two Stage, Single Phase Air Cooled After Cooler Automatic Tank Drain Mounted Magnetic Motor Starter Installation kit: 4 each 4×4 mounting pads and 1 each 4&#…
www.pacificaircompressors.com
7.5 HP TWO STAGE CAST IRON V-4 CYLINDER AIR COMPRESSOR 25 CFM, 575 RPM
CHAMPION AIR COMPRESSOR 7.5 HP, SINGLE PHASE, 230 VOLT 80 GALLON VERTICAL TANK WITH AIR COOLED AFTER COOLER AND AUTO TANK DRAIN If you are looking for the BEST 7.5 hp two stage single phase compres…
Champion VR5-8 | 5 HP 80 Gallon Vertical Air Compressor
Save on installation costs with the Champion VR5-8 vertical air compressor. It features a control panel with a starter that is already mounted and wired.
www.industrialaircompressors.biz
7.5 HP 80 Gallon Air Compressor | Champion VR7F-8
Reduce in-tank rust with the Champion VR7F-8 air compressor. This 7.5 HP, 80-gallon unit features a timed tank drain for automatic condensate removal.
