If you are looking at that model, I would recommend getting the 80 gallon tank and a mag starter that they have at $1,779. A 5 Hp is going to be pretty rough on the pressure switch otherwise, and the increased tank size will give less cycling. Any of these compressor's should work fine for many years. The FCT05C55V6X-A2L1XX has a 3600 RPM motor which is going to mean more noise, the FCT05C55V8S-A2L1XX has an 1800 RPM and flows more air for not much more.
FS-CURTIS CT Series 5HP 2-Stage 80-Gallon Vertical With Motor Starter Model Number: FCT05C55V8S-A2L1XX 1800RPM MOTOR CFM: 17CFM AT 175PSI Voltage: 230/1/60 230-VOLT 1-Phase Outlet Size: 1/2''npt DIMENSIONS (LxWxH-In.) 33 x 27 x 73 Weight: 515 Lbs Warranty: 1-Year Limited Motor Starter
www.aircompressorcfm.com
Also may be worth looking at:
*PLEASE NOTE DUE TO THE EXTENUATING CIRCUMSTANCES LEAD TIME IS EITHER IN STOCK OR UP TO 17-19 WEEKS. PLEASE CALL FOR DETAILS. The Champion Centurion II, now called the RV Series is engineered to deliver industrial-rated dependability at an affordable price. The RV line offers maximum...
