I have an old 20gal/110v compressor that I am a bit scared to use now - the tank is rusted (stuck a borescope thru a port on the tank). I know where the compressor came from it wasn't overly well taken care of, either, but after researching compressors and seeing the aftermath of compressor tanks going "poof" - I think it wise to retire the one I have.
That brings me to the thread.
What I want is an upright/vertical 60-80gal, 240v single phase compressor that won't take up much floor square footage (as opposed to a horizontal) that is going to last, but isn't overly expensive. I don't know if that exists... but I don't want to go to harbor freight or northern tool and just "get a compressor". Though, northern tool does have some nice stuff (Quincy, IR, at least I'd think they are "better" than not - maybe depending on the series). I don't think I could ever justify a screw compressor so a conventional compressor, though loud, is what I'd be in to.
As far as uses - the highest volume task I do is pull vacuum with an Air Lift on cooling systems (my truck is a 6.7l diesel - somewhere around 6-9gal coolant cap, I think). That is asking too much of the 20gal I have, but I've done it. Other than that - conventional air tool use is what I need it for 97% of the time (impacts, air ratchet) with some painting in there in the other 3% along with the vacuum and occasional rotary tool use (die grinders, sanders, cut off wheels).
Thoughts from those that may have more varying compressor experience? What to stay away from or what to look harder at?
I'd look harder at the used market, but what scares me is the maintenance - or lack-there-of. That was what I got when I got my current compressor - already not in good shape, though it is fairly old (not sure how old but maybe 15-30 years). I just want a nice, relatively large compressor that I can trust and won't have to worry about (of course, keep up on the maintenance also).
