Ray,
I'm really enjoying this thread. All the great guys on the forum have got me adding to my to do list like crazy. Thanks for taking the time to share.
Dave
Which of these are you actually using Ray?
http://hubbardspring.com/subcategory.php/category/48/Spring Washers
"Billy G"
Looks like we'll get to the shaft early today. The boss doesn't have anything planned for me today.
I'd swear I had some previously hardened shafts around but, no dice. Right now, the shaft is in the oven. It's 1045 material about 15/16" diameter that we'll heat treat to RC42. According to the book, at this hardness level and diameter being under 1.25", it will harden all the way through uniformly if a water/brine quench is used (not so for oil quench). RC42 is chosen because it's still easily cut with carbide. Once you get beyond 45, I use ceramic inserts.
The shaft needs some hardness mainly because of the small section that rides in the radial roller bearing. Soft metal would deform in fairly short order. Also, hard metal cuts with a smoother finish (at the expense of requiring more cutting pressure).
Here's what it looks like -and unfortunately, the piece is a little more complicated that I'd prefer. The extra diameters are driven by the bearing I happen to have on hand. BTW, I'm treating two pieces of stock. This piece has several critical dimensions. So far, I've have good fortune and haven't blown any pieces yet -but now isn't the time to get cocky. This is going to give me a run for my money because it's thin, will require slightly higher cutting pressures -and I'm shooting for -0.0000, +0.0002" tolerances (translated: it's diameter cannot be under spec and is allowed to go over by 2 tenths). If I get in a pinch, I will resort to using grinding compound to get the critical parts in spec.
OK, see you in a couple hours when the stock is done cooking.
Ray
That part would be an ideal candidate for a good cylindrical grinder. Turn everything .001-.002" large and then spin it between centers on the cylindrical.
It could also then be turned in the soft state, heat treated to the ideal hardness without regard to cutting suitability, and ground for size and finish.
I'm sure a machinist of your caliber will do fantastically, perfectly well on your lathe but a cylindrical grinder is a pretty neat tool to have.
You should be on the lookout for a good B&S 13 or Cincinnati #2 in the future.
Super versatile machines and I believe you'd use the snot out of one if you had it.
You're absolutely right! I'm doing a compromise for a few reasons though. Ideally, I'd turn it slightly oversize with some normalized soft metal then take it down with the TPG or better yet, a cylindrical grinder. Being the kinda guy I am, I used the old TPG for parts as, it was way too big and heavy. Also, even if I had a cylindrical grinder A) I'm completely out of room in the shop and B) I'd have to teach myself how to use it first .
Also, I'd prefer this piece to be about RC 50 but low 40's will have to do. I've already thought of re-making the part the right way once I get this TPG in a functional state then, swap-out the original one. We'll see how this goes...
Ray
BTW: Hmmm, "machinist"... -not so sure about that title yet...
I'm completely convinced that title fits you. In fact, having seen some of your work, Master could precede that title.
