- Jun 12, 2014
- 4,824
You will want to lower the knee and swing down the head (remove the power drawbar) to lower the CG, you will want a ratchet to pull the mill up into the trailer. See if you can remove the DRO/CNC control head, light, etc. as you do not want that bouncing around on the trip. You still need a means to lift the mill (2T hoist or check if he can block it up in advance so you can get the pallet jack under the mill and it still will be tippy. Once in the trailer, bring some 2x4s or similar, a saw and electric drill with screws, so you crib the base into place. I recommend wrapping the mill with some packing stretch plastic wrap (get a roll). Be careful with tie downs placement that they are not over sharp corners that can break the strapping nor likely to damage something on the mill. As Woodchucker mentioned, use a line or a reversing ratchet winch when loading/unloading, with the weight it can be very hard to move and once it gets moving very hard to stop.
Make sure you get all the manuals, parts, handles, etc. for the mill as it is very easy to forget stuff in the loading process.
I have my mill on a rolling base which also has feet that can raise the base about 3" so it is easier to move with a fork lift for loading.
