The bad handling probably could have been solved by lowering the coupler on the trailer. You had the mill far enough forward in the bed but, the trailer was tilting down enough that the rear axle wasn't doing much. This effectively reduced your tongue weight! Multi axle trailers must be level when loaded, bad things can happen quickly!
In a pinch, you can stop the wagging by adding weight over the truck's rear axle. Stop at Lowe's for 6 bags of play sand and pile them against the tailgate, 300 lbs makes a huge difference! (Or your wife's favorite mulch)
Beautiful mill, congratulations!
