PM 1340GT delivery and setup
Just a thought but removing the tail stock and compound slide would lighten the load a bit. And avoid damage if something goes amuck.
Hardest part is finally over!!!
Sent from my ONEPLUS A5010 using Tapatalk
The manual showed pics with both in place so I didn't remove...
Thanks Roger for the tips. I will report back. Definitely not going to bolt the table to floor though.
I wonder how this large is so much in demand. Good sign overall that more people are getting into doing stuff in the country.
I have finally rigged up the lathe, the hairiest part would now be to put it on the table.
Your lathe is probably rigid enough, but South Bend said their lathes should be bolted to the floor.
I noticed there is no 0.7 and 0.8 mm metric thread option. There is 0.75. so I can't do those threads then?
I have never seen a 0.7 or.08 thread.
All the metric I have seen are in .25 increments.
I did once have to do 4-80 threads, that is another story.
