- May 16, 2016
- 1,701
You just turn it down like I described There is no reason why it can't be round, the bottom part registers in the wider part of the slot, the top part just gives it more thickness so it's stronger.Ok, I get the first part, to narrow the width of the plate to the widest part of the "T" slot, and it sounds like the first line of the second paragraph is decreasing the thickness of the of the plate to the height of the "T" slot, but how did you decrease the width of the plate to fit the narrow part of the "T"? I know how I would do it on a mill, but not sure how to do it on lathe. I guess you could mount a cutter in the spindle, then mount the plate to the cross slide and slide it across?
