If you make tool holders as seen in post #24,I would encourage you to make them of thicker metal. I'm afraid the thin metal above and mostly below the tool (1/8" ???) held in the groove might start to sag down a little from the pressure of the screws and the pressure of cutting also. The top of the groove could also start to bend upwards if not thicker.
About the KRF illustrations shown: It is ALWAYS BETTER to have an angled tool presented to the metal so that if it swings under the pressure of cutting,it swings AWAY from the metal,rather than swinging INTO it. The KRF cutters shown would swing INTO the metal if they slipped,ruining the job and possibly springing the bar being cut into a curve,causing a crash and ruining your chuck from the strain on the jaws. I don't know why they designed them that way. If you have read "how to run a lathe" or the Atlas lathe manual,they mention this placement of lathe tools to swing away from the metal,not into it. Best to play it safe for the sake of your chuck and machine.
