- Jan 6, 2017
- 1,215
May get there, if / when the epoxy fails.
Do you know the thread pitch.
Apparently there are two common m5s used on razors .8 and .9
According to that link:
"Since M5x0.8 is a little larger, a handle threaded for it will often work with the smaller 10-32 bolt on a top cap."
Try spinning a 10-32 screw into your handle. If it fits, Rockwell sells replacement heads, caps, everything.
