How To Get New Arbor Press Off Of Semi Truck???
I GOT THE 10" WHEEL ON E-BAY FOR 20 BUCKS . THE SWING ON MY LATHE IS 11" .
IT HAD A SQUARE TAPERED HOLE THAT I BORED OUT TO 1.250"
I USED THE PRESS TO MAKE PARTS FOR ITSELF HERE IT IS BROACHING THE FIRST OF 2 KEY SLOTS .
THE CUTTER FOR THE GEAR TOOTH IS A SINGLE FLUTE DEAL THAT I GROUND BY HAND FROM AN OLD 3/8" ENDMILL .
IT DOES NOT HAVE TO BE PERFECT , JUST CLEARANCE TO THE LAST TOOTH .
BY THE WAY , THE PITCH OF THE RACK IS 11mm .
HERE IS THE GEARSHAFT AFTER IT WAS TURNED DOWN AND THE SPACER & 3/16" KEYS IN PLACE .
THE M8 HOLE IN THE CENTER IS FOR THE BOLT THAT KEEPS THE NEW HANDWHEEL
IN PLACE . I USED THE BRASS BECAUSE IT's NICE MATERIAL & I HAVE PLENTY OF IT .
I MADE THE KEYS FROM 1/4" HEX STOCK OF ALL THINGS .
I just took advantage of Enco's Leap day sale (25% off plus free truck shipping) and ordered a 3 ton ratcheting arbor press for $147 to my door.
Chris
BUT WAIT , THERE's MORE !
ENCO DUST DROPPED THE STANDARD PRICE FROM $196.54 TO $175.95 .
THAT MEANS YOU COULD GET ONE DELIVERED OR $131.96 WITH MAXIMUM DISCOUNTS .
BOY DO I FEEL FOOLISH , OR DO I NEED ANOTHER ONE ?
3 Ton Pressure, Ratchet Leverage, Manual Power Arbor Press
Machine Type: Mechanical
Pressure: 3
Maximum Work Diameter (Inch): 12
Base Length (Inch): 18
Model #805-1035
Low Price: $196.54 ea $175.95 ea
Availability: In Stock
Quantity Master Catalog Page 601
Enco doesn't offer the free truck shipping too often, anyone know if you can pick it up at one of their facilities without paying for shipping?
Chris
Pressure: 3
Model #805-1035
If the sales line up to get it for $131.96 that would be a crazy good price,and everyone should pull the trigger on one!
Once i make a good purchase I never complain if it shows up cheaper later. I'm still very happy with the $147 price.
Chris
Today (May 17th) through 11 p.m. ET.
Cyber for 25% off and Monday for Free UPS Ground Shipping.
With that said I just ordered their 3-ton Ratcheting Arbor press that requires Truck Shipping, total price $131.96 and $0 shipping charge. I called Enco; they verified that the shipping is FREE.
Mike
