- Dec 18, 2019
- 6,447
PrusaSlicer is based on Marlin 1.0. I searched config.ini and there is no "linear advance." During the Z calibration, I noticed the line thickness was not the uniform along the X axis. I found a discussion on Klipper and Input Shaper on the Prusa forum. Interesting, but at the moment over my head. Would require a bit more study. It only seems to be a single thread, so not enough to proceed from.Too much tension can cause ringing, but it mostly just a function of mass. The table is heavy so it tends to bounce at the end of it's travel, and in the prusas' case, the head isn't a lightweight either. There are ways to reduce that, but it's complicated. Look up "input shaping" you would need to confirm what firmware Prusa is using, but I'm pretty sure it's Marlin. I also mentioned pressure advance before, and for Marlin it's actually called "linear advance" That one can be done pretty easily and can help a lot with keep the extrusion width steady.
I don't see any parameters like this in PrusaSlicer. Is this basically related to accel and decel values, or what? Klipper shows how to instrument your printer which is pretty neat.
