- Oct 13, 2014
- 6,703
Aw don't regret it, there will be other deals, besides that was a change gear lathe which can be PITA if you want to change threads and feeds often. Be patent, when the right machine comes along you'll know it.
Even if the logan was in real good shape, it's still a change gear machine. I'm way too lazy to go through that routine everytime I want to change my feed. Change gear machines don't sell real well in the midwest. There are too many qc machines available. What part of the country are you from?All good advice thanks.
I agree with what JA has stated. But I'm going to add one more thing. Start with a small lathe and not only learn how to use it, but also learn how to use it SAFELY.
First of all...Thanks for all your replies. There seems to be some great experience and knowledge far above what I have in this area. I am a retired electrician so doing any "motor stuff" or getting power to any machine is where my expertise ends.
With that said let me respond to a few questions. My "shop" is a detached 26'x32' garage with 12' ceiling height. I have a beam across the center for lifting purposes only (no structural support) with a couple of rolling chain hoists. I also have access to a car hauler so picking up-delivering a machine to my shop should be doable. The budget is a little flexible, but I don't want to put too much into the machinery till I see how much use it gets. I have been looking at some used lathes in the $750-$1800 range, with a 9" to 16" swing range. It seems that the 10"-12" is a pretty good all around size (?). As for mills, I've looked at everything from "mill-drills" up to 9"x42" bridgeport style machines ($500-$3000). In reality I will have to pick one (lathe/mill) to purchase first. I can't afford both right now. Any advice would be GREATLY appreciated!
Thanks again!
Terry
