That's kind of what I was suggesting earlier, before the underside of the part was revealed. But yeah, slice off the whole front, make a new piece and bolt it on. That's what I'd do if a new part was exorbitant. Don't know if jareese has access to a suitable mill, though...I wonder if you could cut out the front “plate” that’s cracked and pin and screw a steel piece in. Once pinned and screwed remachine hole and tapped holes?? I’m real curious on part cost as you are I’m sure. Good luck!
I have access to a mill at work, but the handle and cross-slide lead screw need to be replaced as well.That's kind of what I was suggesting earlier, before the underside of the part was revealed. But yeah, slice off the whole front, make a new piece and bolt it on. That's what I'd do if a new part was exorbitant. Don't know if jareese has access to a suitable mill, though...
It's a heads up so if I see her first I duck into the corner and hide until the coast is clear. Works well.
Really a great way to go. Makes so much sense .That's kind of what I was suggesting earlier, before the underside of the part was revealed. But yeah, slice off the whole front, make a new piece and bolt it on. That's what I'd do if a new part was exorbitant. Don't know if jareese has access to a suitable mill, though...
