Ok, so I just spent some time looking at mine. I learned two things. 1.) My apron has an adjustment "gib" towards the tailstock end that I didn't even know was there. Mine needs adjustment. 2.) I was looking for my nice zero flute countersink. I found it in the chuck of my tailstock.
But, as
@Dabbler just mentioned, I think that you may have to remove the bearing block for the 3 rods on the tailstock end. Take a look at page 33 of the PM manual. There is one bolt and one pin holding it on.
I would remove the gibs on the splash shield side of the saddle. Then, that bearing block on the tailstock end
while supporting the apron (run the apron down towards the tailstock). Take the two SHCS out of the saddle that attaches it to the apron. Now, you should have enough flex in the 3 rods to move the saddle and apron toward you. measured 12mm for required movement before the gibs you cannot reach will clear the bed. Now you should be able to lift the saddle off the apron. Take your time because the pins holding those two castings together are going to be snug.
Wish I was closer or I would drive down there and give you a hand.
