- Aug 3, 2017
- Location
- Gaston, OR
The truck is high enough I'd figure you could pull the transmission on the floor and use a floor jack to lift it into place (plus a buddy or two ). I just googled quick go find the 1800 reman price (and perhaps only $2700 new from Ford?!?), But am enough of a DIYer that I'd just do it myself in the garage.Yep, I've gotten estimates of $1800-$3000 if I pull it and bring it in. And I just don't have the 'oomph' to drop it and reinstall.
Now if I had a lift, a trans hoist, then maybe. . .
I read on one forum about (3) bolts up under the first valve body that come loose.
Though there are others that say that isn't the problem.
We were coming home in it one night after our first long drive in it and went through an intersection that was washboard from heavy truck traffic.
This beast has a very stiff suspension and we rather bounced a lot through the intersection.
It immediately started to rev out in 'D' as if it had been put into neutral. I coasted into a gas station and got it to move in 2nd.
Nursed it home. Next day tried topping off the fluid, nogo in 'D' but was still somewhat functional in 2nd.
Took it for a run down the road and 2nd started to fail. Crawled home in 1st.
By the time I parked it where it sits today, only 'R' and 1st were working.
Dropped the pan a couple of weeks later and the fluid was very clean, no debris in the pan at all.
Was hoping that maybe the filter had failed - nope.
And that it where it has been at for two years now. . .
Of interest, I ALSO found a replacement for $2500 or so that has a PTO! That sounds like fun...
