- Feb 1, 2015
- 9,625
I agree with the consensus. I would definitely push to have the problem corrected. From the photo, it looks like they used prefabricated trusses. You need to determine who is at fault. Are the trusses built to spec? Are the specs. wrong. Has the construction crew erred in their framing? Three possible causes with the truss manufacturer , the construction crew, and the architect all pointing fingers at someone else.
I am surprised that the building inspector that that slip by. It's a good thing that you have photos of the defects. If it were me, I would push to have the problem fixed properly, even if it meant having the roof torn off and redone. Barring that, you should be looking at a substantial settlement for the shoddy work.
When I see workmanship like that, I always wonder how much more is there that I don't know about. On the various constitutions projects we have had done, I would go around after the workmen had left for the day, noting any deficiencies and ether correcting them or pointing them out to the contractor the next morning.
Good luck!
Good luck!
