Well, measured the bores. They all measure out to around 0.001-0.002 thou taper. About the same for out of round.
thats pretty darned good for an engine with around 130,000 kms and an unknown service history.
that low a measurement can be as much my own measuring error as much as actual taper. Always a little tricky to transfer the measurement from the bore gauge to the micrometer. Takes a very practiced “feel” and I’m a little out if practice, despite doing hobby machinist work.
Low wear numbers probably has as much to due with the low friction pistons and rings as much as anything else.
Now I’m ready for parts to show up and start building it back up again.
Should be done just in time to get the mvi done (due end aug).
The missus will get a month or two driving (possibly 2.5-3 months) and then back into winter storage. At least next summer she’ll get a full spring/summer/fall out of it.
Put the inspection scope down the header/converter combo to see what the honeycomb looked like. Surprisingly enough, no melting, no clogging. That, combined with no cat efficiency obd codes, gives me enough confidence to put it back in place and see what I get. If it starts throwing codes or other wise starts causing problems, I can always replace the cat later on…
