- Apr 30, 2015
- 11,328
I think what we are seeing now is more "disposable" vehicles- sad but true.
I've had similar experiences with underhood plastics
Yep, thats how I “weld” plastic, but I use a wood burning tool. Lower temperature, less plastic damage….I purchased a plastic welder last year. I don’t know how I survived before what a great tool. I wish I had one in my sons earlier years. So many plastic toys thrown away because of a little plastic clip broke. Not any more!! Ps one can be made from a soldering iron and like plastic material.
Nope, it's oil. Valve seals were toast and these engines (Peugeot) actually have plastic oil control ring. Yes, you read that right; they put PLASTIC in the oil control rings on an INTERNAL COMBUSTION ENGINE PISTON!#1 and 4 cylinders must have been running really rich to produce that much coke. Which is weird as this is a direct injection engine, right?
As OEM designed, pump is aluminum, pipe is 100% plastic, end to end. They split/crack where the o ring mounts:That pipe a real hassle to change and is used in many makes, my brothers octavia's both have plastic pipes coming out of the water pump. I don't remember is the end of the pump on the N12 engine plastic or aluminium, if is aluminium on aluminium that is a very good solution.
