To be fair I have cleaned and de-rusted the spanners (mostly imperial) to a decent functional level, in my 'reserve' collection but they're not exactly pristine.
As for organisation, I'm getting there. The main issue is one of space and time.
I have
acceptable storage for all of my 'first line' tools.
However, I currently have lathe tools and endmills in the same two drawers and mixed machine work and tool holding in another couple of drawers (in my roll tool cabinet). That sub-optimal situation is down to space constraints I have right now.
I do have plans for a set of drawers beneath...hang on, let me show, not tell:
So, I want to put drawers in the right two-thirds of the shelf (so that's about a metre). Six drawers I reckon; two columns of three. Top two rows being fairly shallow drawers and the bottom row being deeper. That should handle the milling/drilling tooling that I'll be using regularly.
The space on the shelf to the left of the drawers will have open shelves for containers of small/short pieces of stock.
The space between the left wall and the legs will be filled with poly pipe/square conduit arranged horizontally to hold longer stock (up to about 800 mm).
That will give me space in the roll cabinet to have just my lathe tooling in the top five drawers and the remaining two drawers for 'other stuff' (reconfiguration of storage is always a battle plan that never survives the first contact
The wooden tool chests you can see to the left of the mill, are in a liminal state at the moment (with mostly metrology stuff in them) but awaiting the next reconfiguration triggered by the installation of the above-mentioned drawers under the mill.
I also have to print off labels for the drawers in the dirty 'cream' coloured metal card index in the left of this picture (in a different location in the workshop now):
The top two rows I generally remember what's in which drawer, but the rest it's a case of opening and closing until I find what I need.
Finally, I have this:
Which is currently empty, has a fair proportion of slightly sticky drawers (wood drawers with wood runners) and is too tall really to go anywhere good. I'm toying with the idea of cutting it in half (the 'chassis' would allow this) and seeing if that makes either one, or both of the halves more useful. I'll need to paint whatever I keep, because it gives ugly a bad name (you can just see on the left front corner, where the previous owner painted the left side 'Warco green' and then gave up).
Okay, so that's a fair bit of work and time (especially given that, if I want the drawers I'll build for under the mill to not be a disaster, let alone presentable, I'll have to go slowly; I'm no cabinet-maker!
But right now, I want to get my lathe up and running and finish off some parts that I started before I began my "Tranche 2.0 lathe improvements" that got delayed by the logjam that was the arrival of all that bloody plastic and my mill.
Phew...just posting about it makes me out of breath!
So workshop organisation right now is very much a case of little victories.
