- Dec 18, 2013
- 2,235
Let me add that up...$100, $150, $175 I hate the cost of electrical
A Portapower is a really good investment also, the hydraulic clam shell makes up for the lack of a toe jack.I added some needed shop tools this week. One is a 5-foot pry bar, which is quite useful for a lot of things including nudging big machines.
And I bought a pallet jack. I suspect that is a multiplication tool—it makes other things possible.
Oh, boy, have I been snagging end mills and mill cutters that seem to be good buying opportunities.
The RPC has arrived but I’m in Idaho all week and haven’t seen it yet.
Rick “watching a lot of YouTubes of people moving Bridgeports” Denney
And here I honestly thought I was the only one who struggles with this! I ended up making the 20 mile one-way run to Pratt Electrical in Olympia this morning to drop another $80 and another $30 at Home Depot. Got more than I will use this time, more stuff on the shelf that probably won't work for the next LOL. The clerk at Pratt must have been through this 1,000s of times. "Yep, frustrating, they provide nothing and it can be surprising what all is needed."Let me add that up...$100, $150, $175 I hate the cost of electrical
Got a 10-ton porta-power alreadyA Portapower is a really good investment also, the hydraulic clam shell makes up for the lack of a toe jack.
^^^ this is what always happens. I still have a 30 amp cord plug I have moved in my electrical drawer at least 40 times now looking for things, plus half a drawer of other electrical remnants.And here I honestly thought I was the only one who struggles with this! I ended up making the 20 mile one-way run to Pratt Electrical in Olympia this morning to drop another $80 and another $30 at Home Depot. Got more than I will use this time, more stuff on the shelf that probably won't work for the next LOL. The clerk at Pratt must have been through this 1,000s of times. "Yep, frustrating, they provide nothing and it can be surprising what all is needed."
Motor with the cable clamp, soow 14/4 (4th wire needed for reversal) to the switch with a connector so I can remove the motor. Dang it, what was I thinking buying L6-20???? Do I have a L14-20 set???? Cable clamp to the drum switch. Drum switch has insufficient room inside to turn the EMT nut, must spin ell fitting. Means the side to power can only be a straight connection. And after that an offset for the switch box. A motor cut-off rated switch. May as well add a 20a 110 outlet for future DRO. Get a 20a receptacle. A cover to fit switch & outlet. Now where is that THHN??? Dang, how many connections is that? Do I need a deep box? Cable clamp. More soow. Another L14-20 plug. Thank goodness I's already put a L14-20 receptacle. Oh, and a plate to put on the column to hold the drum switch and box with the motor cut-off switch/duplex outlet. Stopped work on the plate to eat lunch . . . . This is turning into "What did you do in your shop today?" Argg back at it.
I hang my head and mutter over what I have from wiring up the Logan lathe and the Monarch with a RPC. I know there is still some 8/4 soow, 10/4 soow, a double set of L21-30 plugs and receptacles (hey, lets also get some 120v for light etc. and only run one cable ignorance). Plus wiring up a SPC as a favor for the person who walked me through all the repairs. Then from what I had wired up and took down when I moved, a couple of ammo cans of 1/2" & 3/4" EMT fittings, 4" boxes with 1/2 the knock-outs gone, 3/4" hole plates to 1/2" but of course NOT what I needed to re-wire the mill when I had to get a new motor. But I did have the grounding screws and EMT nuts^^^ this is what always happens. I still have a 30 amp cord plug I have moved in my electrical drawer at least 40 times now looking for things, plus half a drawer of other electrical remnants.
You forgot a package of those green screws for the box ground wire...and wire nuts and zip ties. lol
