- Dec 21, 2018
- 2,058
I bought the "3 ton" (sort of, maybe, kind of) Chinese one from Vevor. It needed a brass plate/shoe behind the front adjustment screws, I made brass knurled adjustment screws to the side. Added set crews to hold the handle in place. The pin that locates the press plate had been sheared off, fixed that. Now it needs a sturdy stand or bench with an opening to straddle. It easily pushes keyway broaches. I intend to make some dies to form some sheet metal. The end of the ram has a hole for attaching them. It is so much faster to use than my hydraulic press (for things within its limitations.)will make the necessary improvements”
I forgot to add: The vertical clearance is just barely enough to allow me to use my broaches. I suspect the smaller versions would have a problem broaching.
