That box makes me feel warm and fuzzy inside...great score man.Just picked up a Gerstner O42 with a 1950 Machinery Handbook in the drawer, Starrett adjustable parallel set and an old style Lufkin 0-3” depth mic with a 0-1” point.
All for $150. Very stoked on the box. It will clean up nicely
Cutting oil is my blood.
Yeah 24 bucks I was scratching my head going is there a number missing but im not gonna complain by any means. And the steel tooling plates will get some use for sure...And that is how I keep adding machines to my inexistent garage space... You buy something to use part of it and then you just can't bring yourself to cannibalize it...
Oh, and while I am at it... 24 bucks???!!
From the ad….Keep in mind that a) it just has plain holes and b) the Ø8.1mm holes are ~10mm on center - not enough meat to thread the holes.
I admit that I only scanned the fine print since I didn’t plan on using the plate as a true fixture plate. However, since not all of the holes are round as stated, the plates that have been received exceed the 1 blem per plate and don’t meet the description.From the ad….
”did XRF test the plate, but my machine just tells me its aluminum. I do not know concretely if it is 60 series or 70 series, but the XRF test does tell me it is one of those. The holes ARE able to be tapped at will: With a sharp cutting tool: However, the plate will arrive without any holes tapped. You can tap the holes if you wish for use. A (M10x1.5mm) tap cuts very nice clean threads for further bolting.”
So, if it won’t work as advertised I’ll have to decide if I’ll send it back or use it for something else.
John
Let us know what the 3/8-16 tapped hole looks like: I’d try one, but since I plan on using 1/4-20 bolts/studs to secure parts to the plate and the plate to the mill table (I have custom T-Slot nuts with 1/4-20 & 10-32 holes for my table), I’m not inclined to experiment.3/8"-16 fits those holes just fine for fixturing. I can't think of a better way to mount small one-offs, especially when custom fixtures can take more time to make than the part you need to hold down. Plenty of holes to choose from, I speculate I'll get my value meal's worth out of it.
I grabbed a few 3/8 bolts from the bin the other day when I was figuring on how I'd hold this long, thin part that I need to slot. I haven't cranked on a tap yet, but I've got that 95% certainty vibe going on about it. The numbers work out fine for 3/8, and Mitee Bite type stuff is available in 3/8, so I think it'll work out. Else I'm gonna have some nifty patterns on my BBQ chicken.Let us know what the 3/8-16 tapped hole looks like: I’d try one, but since I plan on using 1/4-20 bolts/studs to secure parts to the plate and the plate to the mill table (I have custom T-Slot nuts with 1/4-20 & 10-32 holes for my table), I’m not inclined to experiment.
