Those of you that use Anchor Lube, do you use it straight, or diluted? The instructions say one can mix up to 50% water. I did that and had it in a kiddie paint cup. After a while it grows mold, which reduced my enthusiasm. Anyone else have that experience?
At least it doesn't smoke too bad. And you do have to clean it up, but that's no different than Tap Magic which also stains. Tap magic also seems to corrode stuff. Forgot to clean a drill bit and put it back in the index. Next day there was corrosion in the index
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
