Two tools find new home
ML_Woy
Apr 28, 2012
138
Over the past month I have been working on acquiring two new tools to just about fill out my shop. First is a carbide tool grinder from ENCO that I have converted to use Aluminum Oxide stones for grinding HSS and the second is a Delta 6" x 48" belt sander.
I picked up the grinder from ENCO and like all Chinese manufactured tools it needed some work to get it into shape. I had read and viewed many of the video's on YouTube regarding tuning up these grinders and I have to say this one was in pretty good shape. The trunions needed to be milled because the bolts which tightened them down did not line up with the arcs cast into them. Now they swivel nice and freely. The guards around the stones needed to have thier radius enlarged to accept Norton 6" stones about .040". The label on the front of the grinder said "Only use 6" stones", however the stones which came with the machine measured less than 6". The valve for the water cup came broken in the package and ENCO had no replacement part. They would only take the whole unit back and replace it. Since shipping was $70.00 I decided to keep it and fix it myself. The valve is strange in that it is threaded 1/4" pipe thread on one end and metric threads on the other. I am making an adapter to use the metric threaded plastic hose with a U.S. standard brass valve. Here are a couple pictures of the finished grinder. Oh, total cost of finished project was $350.00 for grinder including shipping, $300.00 for two Aluminum Oxide stones from Norton through MSC, steel for stand and casters was recycled material.
The second project as the cleanup of a 1945 Delta 6" x 48" belt sander. I found the sander on Craig's List in a nearby town. The guy had a huge garage full of machine tools, had recently moved from a farm to town and needed to clear some space. The sander only had some slightly damaged parts, rust and the look that it had not been run in a long time. I took it apart, removed all of the rust, replaced the lower drive bearings, the local bearing shop had to get them from Tymkin for the cost of $68.00, fabricated a missing piece which allows the table to tilt, some grey paint, and built a dolly to move it around on. Total cost in the project, $425.00.
Here are a some pictures in the painting stage:P1080433.JPGP1080434.JPG
Here are some pictures of the finished project:P1080439.JPGP1080440.JPGP1080441.JPG
As some of you who read this Forum a lot may have seen my posting for dimensions for the two horizontal fences used with this sander when you lay it flat. Well out of over 1000 reads no one seems to have on of these so I am moving forward with building the parts from drawings I have created from the exploded parts page of the documentation which came with the sander. Material has been purchased and drawings are complete. Looking forward to building the parts.
M.L.Woy
P1080438.JPG P1080437.JPG P1080433.JPG P1080434.JPG P1080439.JPG P1080440.JPG P1080441.JPG
Hi M.L.,
I bought a 6" delta belt sander like yours last fall. Like yours mine needed paint and a new stand. I have never seen one of the fences for use in the horizontal position - actually I never knew the existed! I did wonder about the bolt holes which obviously are for attaching it.
Your sander looks good and I look forward to seeing the new fence.
Michael
Hi M.L.,
What was the MSC catalog number for the Norton wheels? I've been looking and can only find Camel wheels in a Type 50 plate mount for my Harbor Freight clone grinder.
James
I can almost guarantee that if you head over to www.owwm.org and post a question about the fence dimensions, you will get several answers.
Nice job on the sander! I have the same one from 1943 on a Delta cast iron stand.
Guy in Sacramento
M.L.Woy
