The last couple of days I have been busy in the shop.
I made the magnet wheel for the ignition system and the drive pulley for the governor.
Driven governor pulley mounted in the ball bearing housing.
Rubber belt drive with a 1/4 twist. It tracks just fine thank you.
Catch arm, actuator rod and governor spool made, installed and adjusted.
I need to trim off some material on the cam shaft, the catch arm, and the actuator rod but I want to finish the fly ball assembly first.
If everything works as I hope it will then I will dissemble the engine for painting. I still need to drill the head bolt holes.
Anyone have a preference for the color?
I'm leaning toward orange.
Thanks for looking
Ray
