- Apr 14, 2014
- 3,542
The All Speed drive is silent except for the whirling sound of the belts. If the cabinet door is closed there's almost no noise. The service manual suggests running it through the full speed range on a daily basis. I've found if you don't errant grime seems to build up on the inner surfaces of the sheaves. When that happens, the speeds are harder to adjust to an exact number. Now before I try to turn anything I run it through the speed range. It takes less than 30 seconds to go from one extreme to the other and back.
