I checked the lathe & it is level across at the chuck end & at the tail stock. Since the bed is solid, I have a 1-2° slope to the tailstock to allow the bed to drain when using flood coolant.
I went & bought some 2" aluminum round. I will turn both ends of the test bar equally & bore a couple of 2" sections to press on each end, then I can try the collar test.
I will check back in a day or two when I get this done. Thanks all for the help
