I've wondered about the way the chains move. Perhaps they are filled beyond the specifications, generally specs call for quite a lot of free space. I haven't heard of full cable chains on Vorons, hope it isn't a problem. The type of wire is critical in chains for long life, either PTFE or FEP insulation is recommended. Quality cable chain wire is not cheap. It is one area where a kit might cut corners. Early on the Voron developers and builders used various types of wire that were not good in cable chains, and they had a lot of cable failures. So they learned the hard way.
Canbus would certainly cut the cabling way down, and the canbus boards generally have an accelerometer for input shaping built right in, very convenient. The Salad Fork kit has Canbus included. It is another layer of complexity for configuration and updating, so there is some downside.
Early on I bought a partial wiring kit with those flat flexible printed type cables to replace the cable chains. Many printers such as the Artillery Sidewinder use them. It makes for a very clean cable management setup. They don't seem to have become popular on the Vorons. Hopefully I will be able to use them someday.
Prusa Slicer has a lot of features, it can be set into simple, advanced or expert modes and this exposes more or less of the interface. It has divided the parameters into different groups such as Print, Filament or Printer settings which is convenient once you get used to it, especially if you have more than one printer, and we all have more than one print and filament to work with, so it is a useful grouping. It also allows to save everything into a project file so you can keep your customized settings along with the object files for a complete package. There is a bit of a learning curve with all slicers.
Unlike most slicer developers, Prusa has a large printer farm using it's own printers and software. So they really live by their own features and performance. With 14 developers on Prusa Slicer and hundreds of printers in the farm running 24x7 they have more invested than most companies and they benefit directly from improvements they make.
