- Jan 6, 2017
- 1,234
I worked on this for a couple of hours last night, Ken. When I install the SD card in the Orange Pi, it will boot from the SD, and it 'seems' that Armbian is installed. However, when I power it down, remove the SD card and then power it back up, it boots right back into Android. This does not make sense to me because I thought I had Armbian installed on the Emmc, but apparently not?
I found a Reddit thread from 7 months ago that said Armbian was not compatible with Orange Pi 3 LTS, but not sure if that is really the case. I cannot find that thread at the moment but here is a thread that may be useful.
Here is another Reddit thread regarding Fluidd and Mainsail.
After booting from the SD, did you run the "nand-sata-install" command, to write the OS from the SD to the EMMC?
Disclaimer, I don't know how to actually do that. I just read it here
Installing Klipper on Armbian OS, like Orange Pi
Hi, I just want to share how I installed Klipper, Moonraker and fluidd on my Orange PIs. 1. Download Armbian (I use the debian/bullseye) for your board from here: https://www.armbian.com/download/ 2. Write the image to a 'good' SD card. 3. When booting for the first time, you are asked to create ...
www.teamfdm.com
