For a really good tap, buy OSG EXO taps ( Japanese ) - They are super
and what we used for die work when I was in the shop. They Cut superbly and can do really hard steel as well as Aluminum
We used them to do Rc 52-56 H 11 material for example - and they are strong
A bit old fashion, but if you are concerned, get a 'Starting tap" and pre-start the holes .
in the old days , Taps came in sets of three- Taper (for starting !) -Plug ( normal tap) - and Bottom
A Taper (starting tap) is great for hand tapping as it prevents cocked holes, so a Guide is not necessary.
I have a friend building a 9 Cylinder radial engine and he broke 3 tap in the crankcase.
I burned them out for him using Ben Flemings EDM design which used to be on Yahoo Groups
but I believe they moved to
Home built EDM
groups.io
For info go here
I built mine for about $100, but used shop surplus in doing so
Post edit comment
90 % is a lot of force , be careful !
Rich
