Nope. What I need is a way to hide the purchase from my wife... I mean, the CFO. Everything is in the cart... along with a few other things I have been meaning to buy... The other things have been there for over a month now.
Don't forget to add the Black-Oxide 3/8-24 steel rod & Black-Oxide Steel Round Coupling Nut, 3/8"-24 to go with the thrust bearing for that dial extension. And either a taper or roll pin. Just saying . . .
FWIW my partner and I have a 17 year standing agreement. I only comment on purses and shoes regarding how nice they complement her, and she doesn't ask what goes into the shop.
I'm planning a floating vise build and I need a hole sized for a 1/2-10 Acme tap.
This chart tells me the tap drill size is .400.
This page says it's .405
.400 is impossible to find it seems.
.405 is findable.
What is the correct size?
LOL Sir, I knew exactly what it was for. Just joking about the dial extension option.
Are you making the dial carrier? To me that's the best as well as the simplest way to be able to set pre-load independent of the dial friction. It eliminates the problem. Even more KISS and no different than the saddle bushing is to just put a spanner pin hole in the handle end. No need to mill flats.
