Also have a look at at IOSender for control software. Really excellent open source with active development. Make it super easy to configure the machine.I'll look right into that! Thanks.
Ethernet is preferred if you are using a VFD as the EMI wreaks havoc with USB connections. Basically kills the connection.I'm very handy with soldering and electronics in general, and I have a reasonably well-equipped little electronics lab in my hobby room, so that's a piece of cake.
I was intending to use a simple 5V Arduino that I have lying around, hooked straight to stepper drivers, etc., without an intermediate breakout board. That teensy breakout board has more features than I need right now, but it sure looks pretty good if going with grblHAL. Thanks!
I see there are USB and Ethernet variations. GRBL is USB only, but for grblHAL I wonder which would be preferred, if any, and why?
Shielded ethernet, many are unshielded.Ethernet is preferred if you are using a VFD as the EMI wreaks havoc with USB connections. Basically kills the connection.
I had my PrintNC router running on grbl as a test but I wanted the feature set of grblHAL.
Awesome, please report back on how it works for you.I ordered one of those boards. Thanks again.
By the way, it's convenient that it supports 24V power rather than having to add 5V and maybe 12V supplies. Nice.
Seriously, if you are considering a small CNC Jim has a very good point here. I see them come up occasionally, mostly either used for instruction or owned by hobbyists. If you're comfortable with controls buying a small (stout) used CNC will definitely result in a more capable machine.For a small CNC mill you really can't beat one of these. This one needed a little love, but only has about 30 hours on it. It just followed me home one day. 4 axis, 6 tool changer, full enclosure. Very high quality, made in Austria. Not much bigger than a Tiag. Needs a controls upgrade that I'll get to one day, currently has a Fanuc emulator controller. These were about $35K new, but I have seen a few on the used market at reasonable prices.
