What's the meaning of “Hobby Machinist?” Some say it depends on the definition of what is,, is. In my humble opinion if you make money with the shop, it no longer a hobby, rather it's a business. And according to the IRS,
a business actively tries to earn a profit while a
hobby does not. Simple enough...
That places my home machine shop in the hobby category. And after sixty years of collecting and upgrading tools and machines. I have a shop filled with twelve major pieces of equipment that rivals many small shops. Mostly manual machines except for one CNC machine. My biggest is is a 5,000 pound 2021 Cleveland AV-35 Bed Type three-axis CNC mill. It sits across the isle from my 1951 Kearney Trecker Rotary Head Mill that weights 4,500 pounds. Along with my 4,000 pound 1942 G&E Shaper. Size and weight are not anissue for me. I had the foresight to build and install a 4,000 pound capacity bridge crane covering my 30' by 50' workshop. Along with the ingenuity to move heavy equipment. My main shop has a dedicated 240 Volt 200 Amp single phase load center. And a total of 30 HP RFC in three separate units. Power is never an issue and can run two, three, or four machines at once.
So I have all these great toys. But I consider the CNC machine my biggest plaything. Yes it's marvelous to see it running. The capabilities are endless. However it takes me more time to set it up. Than to simply make a part on my manual machines. More time is spent programming than actual machine run time for any single part. On a manual machine I'll be making chips right out of the gate... It's a far different story for making multiple parts.
My advice for a home hobbyist is stick with manual machines first. If you care to go the CNC route,, Cranking handles is fundamentally important to run a CNC version if you go that route.
