Dear Hobby Machinists Folks,
I am a beginner at metal working who is moving towards building a small CNC mill.
I have a Sherline long-bed lathe and some accessories. Although I had specific tasks lined up for it, I mostly purchased it as a "toy" to learn on. It's a nice little machine that is fun and perfect for educational use. Of course it's very small, but I can think of ample fun projects for which it will be fine. Also, I use it in a spare bedroom dedicated to hobbies, where it's very quiet and so easy to take out or put on a shelf.
Now I'm interested in a traditional-style CNC mill (not those router types). Again, I do have some specific tasks for it, but again, a big part of the build is for the fun and learning that goes along with it. But having decided that, I wonder if I should stick with the small, quiet, light approach, or go bigger? That is, my default plan is to get a Sherline mill, but then I thought that something like the PM-718VT looks mighty tempting too!
The Sherline is my most likely choice, as I'm half way there already with parts and accessories. I'd be going with the 5400 12" machine with extended column. This is the rigid column version (hehe, "rigid" compared to a tilting one anyway), with standard lead screws in "CNC ready" form. I don't see ball-screws being cost-effective on this mill.
I prefer to stick with open-source software, for which the main choices include LinuxCNC and GRBL. At the moment, I think I'm going with GRBL. The reason is that a dedicated linux box would not needed, and any computer, including linux and Macs, can talk to it. A limitation of GRBL is that it's currently 3-axis only, and I do have a rotary table. However, hobby-level operations requiring a rotary table usually only need one or at most two other axis movements anyway.
I'm experienced with electronics, and have looked at options for motor control, etc. I think a straight-forward open-loop stepper-motor system is an appropriate fit to a Sherline. With about 400 oz-in of torque, if one of these starts to miss steps, then the little Sherline is almost certainly being pushed too hard. GRBL only needs an inexpensive Arduino and a USB connection to any computer. Other than that, an E-Stop and limit switches, connectors, etc., are needed. The cost of all that can be surprisingly low, and so a cool little 3-axis CNC mill can come in around $2k including some accessories. I do wonder if it would be too messy for an bedroom-type hobby room, though.
But then the thought of something like the PM-718VT, which apparently has factory ball-screw kits available, seems tempting. Ah, but with a stand, DRO, the higher-tier ball-screws, shipping and tax, it comes in over $7k without any accessories. I'd also need to invest in more expensive servo motors rather than steppers, more expensive drivers, bigger power supplies, and so on. I'd likely go with LinuxCNC or similar rather than GRBL for the extra features. With a minimum of tooling, it could easily creep (or leap) up to $10k. I'd have 400 lbs to move around, and I'd have to put it in a dark, unconditioned garage space. And if I did all that, why not go with a PM-833 or better anyway?
Curses on life's compromises!
What do you all think?
