Quick update: The oil feed line was connected with a 21mm flare nut. I ordered a crows foot; we had 6 days of snow and ice which pretty much shut everything down, however it arrived yesterday. I went out today and:
1. removed the oil feed line. (the flare nut froze on the line and twisted the line off. a small medium recovery to find one.)
2. I was able to successfully remove the second of the 4 nuts holding the turbo to the manifold. A propane torch for 30 seconds absolutely helped.
3. I have successfully loosened 9 of the 12 bolts holding he manifold to the head.
a. the most forward bolt, #1 lower, is effectively shaded by the alternator wiring, requires careful attention not to break something.
b. the #3 lower is shielded by the turbo
c. #6 lower is just very difficult to reach. There is a locking tab that is difficult to bend back. The nut should not be too difficult.,
Plan for Sat:
1. heat and test the remaining 2 nuts - hopefully a standard box end will work.
2. bite the bullet and loosen #1 lower.
3. bite the bullet and loosen #6 lower.
(additionally I have to remove the exhaust pipe from the exhaust brake to the muffller. (required to have room to move parts around.)
If I get this done the turbo should be able to be removed. Once that is done and #1, #3 lower, and #6 lower are loosened the manifold should be a straight pull.
All in all this job is a 4- for difficulty and an 8 for access. (I do not believe the nuts and bolts in and of themselves are difficult. It is an access issue with limited tooling.
Thank you all. Your comments have offered encouragement to tear into something wholly new.
Plan for Sat:
