Show us your Logan lathes!
Proud new owner of a Logan 14" 7502 Chucker lathe. (So is my buddy it turns out - they are perfect twins.)
Needs a little cleaning but is otherwise in very excellent condition. I'm on the lookout now for a tailstock, saddle, cross slide/compound base and compound from a Logan 65xx lathe to get rid of the turret setup. Given the availability of used parts for these 14" Logan I think I have my work cut out for me. Thankfully the lathe was cheap.
If anybody knows of any parts out there, let me know! Thanks!
New member, new 10" Logan lathe.
It came with a QC gearbox, power apron and a Forkardt 3-jaw chuck.
Not sure if the QC gearbox will work with this lathe - I will post a question on that separately. I had a look at the apron last night and I think it will work after I clean it up.
The chuck needs a back plate. I have a blank on the way. This will be my first real project.
Just sold this 9B-17. Pristine!! Three owners (now 4). Hated to do it, but can't justify two lathes.
I still have a 1957, but will post pics after the rebuild is complete.
I just bought my first lathe, a 1947 10" Wards/Logan. Got it from Daryl (Uglydog) after seeing his post about it on a forum thread. Clean, straight and everything feels tight and runs smoothly.
1941 Logan 700. After 76yr it's still serviceable. Bedways are in excellent shape. FILTHY when I got it. Missing a few parts, easily obtained. Missing the steady rest. Old rocker style tool post that I'm thinking of replacing with an Aloris or similar. Over the years someone had retrofitted a Drum Controller to allow FWD and REV of Split phase 1/3hp motor, that may go away. Still think it's fun lathe.
Was the original switch just a simple "On/Off" switch? Maybe RLE can tell me based on his 1947.
A simple ON-OFF switch has almost always been the default on most lathes up to about 12" unless they shipped from the factory with a 3-phase motor installed. But almost all manufacturers have always offered as an extra cost option a reversing switch, usually of the drum style.
If you decide to use a switch that reverses the motor, you'll need to take care not to spin the chuck off the spindle. My Model 200 came
with a switch like that and I removed it. (I don't trust myself!)
