- Feb 2, 2013
- 3,850
Very cool, but they are ripping customers off.I have just installed a 3 HP RPC Kit that I bought on E-Bay, the components came with clear instructions (had the 3 HP Motor) assembled and connected, runs my Hardinge Lathe, Tree Mill and Boyar Schultz Surface Grinder very well.
I'm furnishing you a link to their 15 Hp and 20 HP Kits.
Hope this helps.
15HP Rotary Phase Converter Quick Build Kit | eBay
With this setup you will have a 15 hp rotary phase converter, your 15 hp motor should be rated at 230volt or 230/460volt and a rpm of 17XX or 35XX. -Heavy duty run capacitors rated at 370vac to balance the generated leg from L1 and L2.www.ebay.com
20HP Rotary Phase Converter Quick Build Kit | eBay
With this setup you will have a 20 hp rotary phase converter, your 20 hp motor should be rated at 230volt or 230/460volt and a rpm of 17XX or 34XX. -Heavy duty run capacitors rated at 370vac to balance the generated leg from L1 and L2.www.ebay.com
If you were to source the parts, you could get them for 1/2 the cost of a kit
