Router bits to cut Aluminum.
Savarin
You aren't even talking about using router blades on a (real) mill, but using your lathe as a mill, correct? If so, then how
many RPM's do you turn your chuck at?
CHuck of the other kind i.e. Grumpy
Thats correct, 500 to 900 and a couple of times in aluminium at 1800.
Other times I have the bit held in a tool holder and turn the stack at 900.
Yes, it is amazing what you can do with a smallish lathe and nothing else. well except for your ingenuity.
CHuck the grumpy old guy
Reviving this old thread to add my experience. Yonico 1/4 in. round-over bit with 1/2 in. shank. Cutting C1018 steel @ 660 rpm in vertical mill. Performed well beyond expectations, left a beautiful finish and showed no wear or damage.
