- Dec 3, 2017
- 2,227
I can’t speak to RDM from a position of strength. But I would say that if you decide to try a method, and then, because you don’t quite get why it’s done the way it is, and thus change a portion of that method to suit you, and then are disappointed with the results….its not the method at fault….probably.
Similarly, if the first step is to level the lathe, and a person decides to forego step one in favor of modifying RDM, and ignoring the impact of foregoing step one…it’s not the method at fault.
So if it’s me, I go back and follow instructions as they’ve been laid out. Because it appears those things might have been important.
So if step one is level the lathe, then level the lathe.
On a side note, I’m not even smart enough to understand RDM, and threw it out a long time ago. It’d take someone showing me in person.
Good luck! I think you’re headed in the right direction with RJSakowski.
