- Aug 20, 2024
- 27
So this post is mostly thinking out loud, but if someone has some insight, I'd like to hear it.
So in my ongoing effort to get my older Grizzly 12" x 24" dialed in, I decided to put the cart before the horse and try to align the headstock to the ways. I say cart before the horse because I haven't really done a thorough job of leveling this thing, there's enough twist in the bed that a precision level soon has me chasing my tail. But that's fodder for another post.
Anyway, RDM seems to be a fairly popular and respected alternative to the usual method of dialing in lathe alignment, so I decided to give it a try. For a test bar, I chucked up a piece of 1.25" aluminum heavy wall tubing in my 3 jaw, I figured that would be stiffer than a comparable solid bar, and it was a good length. And right away, I was having issues with the instructions. They say to record the high and low numbers and average them. But why/how are they getting high and low numbers in the first place? Why not just zero the indicator on the low point, then record total runout? Anyway, that's what I did, and I was getting about .002" at the chuck, and almost .060" at 16" from the chuck. Which seemed excessive, if I'm understanding the instructions, that would seem to indicate my alignment is out by ~.030" at the 16" mark. But that's about double what I'm seeing for taper when I turn something. For no particular reason, I decided to swap ends on my test bar, and I got totally different numbers, about half my previous measurements. So then I switched to a 7/8" 416 SS round bar, and got a whole new set of numbers nowhere near the previous checks, much lower and closer together end to end. So in 3 tries, I came up with an alignment error of ~ .030", .015", and .003". Not exactly useful info, what am I supposed to do with that, average all three readings?
My other issue with this method is correcting the alignment by shimming the feet. Seems like this is assuming the lathe is twisted, but if it's leveled when you start, as it should be, then why not go to the source and adjust the headstock directly? I realize not all lathes allow adjusting the headstock, but mine does, and once (if) I ever get mine level and straight, I'm sure not going to mess it up by twisting it again.
Maybe I'm totally missing something here, but it seems to me that if this is going to produce useable data, I should have gotten at least similar numbers from all three attempts. I was careful to make each measurement at the same location on the bars, and I made all the measurements multiple times. I've decided to set this aside for now and concentrate on trying to get my lathe properly leveled, but at this point, I won't be trying RDM again, I'll go with the more traditional method.
And BTW, yes, I'm working on the level/twist again, only this time I'm going to see if time and gravity can accomplish what I couldn't with brute force. More later.
Dave
Dave
