Continuing on.
Using a mix of sanders and wire brushes, I got most of the old crud off.
Both sprayed and brushed on a layer of epoxy primer.
And ontop of that a layer of grey polyurethane.
It looks quite light in the pictures, as it hardened it became a bit darker.
I did so many mistakes here that really ****** me off. Stupid mistakes like how I somehow forgot to mask the top and floor, sprayed way too much paint on and so on.
I will have to get back to this and sand down the runs and do a final top coat again.
I did a quick brushjob on the legs, I think the black should constrast nicely.
To get away off from the frustration of the bad paintjob(I don't like painting but I like a good end result..), I started working on the pump which was the initial problem.
To the left you have the "lid" of the main piston and to the right is the main unit I guess.
The big rod on the lid has a smaller rod inside it, and the big piston has a smaller piston inside it that gets act upon from this smaller rod.
Basically as the saw runs, it acts upon the smaller rod, transfering the motion to the smaller piston down inside the bigger piston.
A closer look on the main piston and the smaller rod.
With the bottom taken off the main piston, you can see this smaller piston. I have taken the seals off it for the photo.
Eventually all that was left to take apart was this part on the lid.
Aaand here we find a completely busted seal.
Hopefully this is all that was keeping it from working as intended.
